white spark plug
Old Feb 25, 2012 | 09:15 AM
larrypac99's Avatar
Default white spark plug
I have a 2001 4cyl auto Accord with 64K. Getting 24 mpg. Decided to check the plugs and the second from left, facing the engine, was very white. I am told this indicated a lean mix, but how should I proceed to diagnose the problem? Other plugs are normal tan color. They are original laser platinum NGK. Should I replace them just for being 10 years old or does that not matter. Appreciate any advice. Larry
Old Feb 25, 2012 | 10:23 AM
A white spark plug is usually indicative of running hot. Gap may have changed and in the incorrect range.
If it was me, I would changed them if they were the original plugs.
Old Feb 25, 2012 | 01:04 PM
kyle102565's Avatar
just change the plugs. all honda or for that matter modern engines burn lean. the additives in gas including 10% ethanol cause this condition.
sirtwist2
Sep 24, 2012 01:36 AM
wannakeepmy94Accord
Mar 14, 2012 08:06 PM
SeanAccord
May 18, 2010 08:24 PM
offroadTRD
Jul 3, 2009 06:38 AM
jon02accord
Mar 26, 2008 10:54 AM
