Window Adjustment
Old Apr 14, 2006 | 12:40 PM
mgelfl
Default Window Adjustment
Hello all,
I have a 1992 Accord 2 door. I believe at one point one the side rear pop-out windows were replaced and is in need of adjustment.
when I close the door the corner of the upperpart rubs with the window post. I know the door is not sagging its seems tobe the pop-out window is not alined properly. There is two screw caps in the frame of the window also.
Any suggestions or help would be great.
Old Apr 14, 2006 | 01:04 PM
sir_nasty's Avatar
Default RE: Window Adjustment
Typically you can simply loosen the screws that hold the hinges on and that will allow you a bit of room to move around/adjust the window to where you want it.
Old Apr 14, 2006 | 01:13 PM
mgelfl
I was told that the window/frame actually can be removed / adjusted. the window frame is part of the side of the car. If you open the door and look in at the side of the pop-out window there is two screw caps. This is the area where the door window gasket makes contact with the frame of the pop-out window
Old Apr 14, 2006 | 01:48 PM
sir_nasty's Avatar
If that's the case and your windows require being removed then I honestly don't know how to/haven't done it.... I could swear that you can just loosen the screws and adjust it... (unless I'm confused about what exactly is out of place...) I'd imagine someone will be along shortly that knows more exact specifications about your vehicle...
jkeely
May 2, 2012 03:48 PM
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
mmazb3
Nov 26, 2007 03:16 PM
