Window installation
Old Dec 29, 2008 | 04:27 AM
TigerRace
Default Window installation
Hey guys. I'm replacing a broken side glass on the rear left door of my '94 Honda Accord and I'm wondering if anyone had any good tips on the subject. Thanks!
Old Dec 29, 2008 | 10:26 AM
hondadude's Avatar
Default RE: Window installation
I'm pretty sure there is a little'blank' in the back of the window space?
What you are looking to accomplish is to get the rear run channel bracketloose.
There is a 10mm nut at the top and bottom of that bracket, I think that the top one is found thru a small hole in the panel............I'm trying hard to have a flashback here .
Then when sliding in the new window it needs to be angled in with the lower front edge leading.
Old Dec 30, 2008 | 02:52 AM
TigerRace
I found the panel access to the brackets and the 10mm nuts were all there. Installed the new window by sliding in the glass from inside the door area carefully, then redid everything in reverse. Thanks HondaDude!
ravenr106
Oct 21, 2011 06:08 AM
ravenr106
Oct 20, 2011 05:32 PM
2006accordexl-passmirrorbroken
Apr 12, 2010 03:01 PM
gqgeorge
Jul 15, 2008 03:17 PM
mmazb3
Nov 26, 2007 03:16 PM
