window washer hose broken
Old Jan 27, 2012 | 02:01 AM
ex man's Avatar
Default window washer hose broken
95 accord ex window washer hose leaks at the connection on the driver side under where the engine hood hinge connects to the car body. ican see it leaking but cant reach it. How do I change that connector where the washer hoses are attach to? Thx...
Old Jan 27, 2012 | 06:40 PM
You might try, splicing hose "over" it. The old hose gets "hard", I have found that if you get vac/washer hose that the old hose fits inside of, you can use a piece of new rubber hose to join the two together....make sense?
Now I can't help with "how" to get at it.....
Old Jan 27, 2012 | 11:29 PM
ex man's Avatar
Thx for the advise
Old Jan 28, 2012 | 09:53 AM
AnthonyMartello's Avatar
Hello,
If you have one, you need to maintain it regularly, so learning easy auto repairs can save your money. Fill your windshield washer reservoir often and check it for leaks periodically, especially when you run out of fluid too quickly. If you find a leak, determine if you can fix it, otherwise, replace it.
Best regards
Anthony
Old Feb 9, 2012 | 07:55 AM
kellysa111's Avatar
ex man....mine is totally broken off. its just a rod hanging off the hood lmao. good luck.
d0n
Aug 11, 2020 01:59 PM
ChappyBob
Oct 27, 2016 05:44 PM
scoostraw
Jun 13, 2013 06:52 PM
ex man
Jul 2, 2012 07:36 PM
jamesejam
Sep 21, 2009 02:37 PM
