windshield fogging horribly
Old Aug 27, 2007 | 06:42 PM
Slambert
Default windshield fogging horribly
ok i have an 03 accord coupe which Ive had for about 2 months. Lately before going to school the windows have fogged where i cant see a thing. Ive tried defrosting with a/c, then without a/c but it will just get worse. The temp is around 80 outside but in the day it dissappears with the heat i guess. Ive put new whipers and everything. Any suggestions? thanks. I couldnt see out the back so i nailed my trashcan this morning. ha
Old Aug 27, 2007 | 07:14 PM
Default RE: windshield fogging horribly
Make sure you have air on recirculate w/ AC on. This will allow drier air for AC, but is worse if AC is not used. W/o ac use fresh air for defrost. You could have something on the outside or inside causing fogging. I would clean inside and outside w/ a good window cleaner.
Old Aug 27, 2007 | 10:18 PM
superballz00's Avatar
Almost A Senior Member
And make sure that it's fogging up on the inside of the windshield. I remember a rental car fogging up on the outside of the windshield once. It started fogging up so I turned the defroster on but it didn't help at all and seems to be getting worse. Then I noticed that it was on the outside and just turned on my wipers.
Old Aug 27, 2007 | 11:06 PM
Tony1M's Avatar
If the heater core is leaking, that can cause windows to fog terribly.
weannaun
Dec 15, 2020 10:46 AM
honker3
Mar 1, 2009 03:20 PM
rnlcf
Sep 29, 2008 09:19 AM
luey42n
Nov 19, 2005 09:30 PM
Jirviss
Apr 29, 2005 03:32 PM
