Sponsored by:
Sponsored by:
Windshield Washer
Old 01-09-2013, 11:03 AM
john_pyro's Avatar
Default Windshield Washer
My windshield washer fluid barely squirts, hardly more than a dribble. It doesn't even make it to the windshield. Been like this for awhile, but now with winter here is really a problem. There is plenty fluid in it. Is there a screen or filter somewhere that may just need to be cleaned? What else can I look for?
Old 01-09-2013, 11:30 AM
I had that at the rear washer of a couple cars. Used infrequently, it would dry up. If it's ever had the opportunity to dry up in the lines, maybe this will help.
Use a hairdryer to warm up as much of the lines as you can get access to. Then run the washer motor for a LONG time. Like a few minutes. It might just need to be flushed out real good.
Old 01-10-2013, 10:48 AM
john_pyro's Avatar
Thank you, I'll give it a try
Old 01-11-2013, 06:33 PM
...or take a bread tie, strip the plastic/paper off the wire. Then GENTLY use the wire to open/clean the hole on the nozzle. Spray them, clean a bit more.
ChappyBob
10-27-2016 05:44 PM
oldschoolsnow
03-02-2009 04:27 PM
honker3
03-01-2009 03:20 PM
Tref
03-01-2009 03:18 PM
bougie_44
10-16-2007 08:01 AM
Quick Reply: Windshield Washer
