Yet another "S light on" problem
Old Aug 2, 2009 | 12:55 AM
Lightbulb
If you can borrow a gage you can see how much is in and how much you still owe the unit.
Old Aug 2, 2009 | 01:16 AM
deserthonda's Avatar
Originally Posted by 91Accord_LX
Added two cans of R134a. The system works now but doesn't get very cool. It may need more refrigerant, I'll check the sight glass on the receiver-drier tomorrow. Does anyone know how many 12 oz cans it typically takes to completely charge the system on a '91?
did you retrofit the the a/c system in your car ?? 91 accord takes r-12 ,, 2, 12 oz cans should be enough to make the system cool ,,,,, system capacity is 32-34 oz
Old Aug 2, 2009 | 12:17 PM
91Accord_LX's Avatar
I wish I knew someone with a gauge I could borrow. Maybe Autozone loans them. The car had already been converted to R134a when I bought it.
Old Aug 2, 2009 | 09:36 PM
Autozone does loan out a gauge set so I'll do that this week sometime. But today we went for a drive and the AC actually got nice and cold. When I first started the car and turned on the AC I looked at the sight glass and it was foamy but then cleared up. I guess I just need to top of the refrigerant. My daughter is happy that she now has a reliable car with AC. That was my goal. Thanks for all the help!
Don
Old Aug 3, 2009 | 08:26 AM
I was going to say that I didn't see anything about evacuating the air out of the system before adding refrigerant. Air in the system will cause poor cooling performance. But now you say it works? So that's good.
Old Aug 7, 2009 | 05:40 PM
I found out the system takes about 34 oz so I added almost another whole can. Now it's very cold and consistent. How do you go about evacuation air in the system?
Old Aug 7, 2009 | 08:18 PM
  #17
If you discharged the R134a from the system when you removed the compressor, then you should have hooked a vacuum pump to the a/c system to remove all air and residual moisture.
If you just unbolted the compressor, and left the lines attached, then no air should have gotten into the system, but you wouldn't have had to recharge either.
Air in the system can't be good for the compressor and probably makes the system less efficient.
Old Aug 10, 2009 | 08:54 AM
  #18
Originally Posted by PAhonda
Air in the system can't be good for the compressor and DEFINITLY makes the system less efficient.
There, I fixed it for ya...
campy19@optonline.ne
Apr 18, 2014 12:31 PM
JohnTaurus
Sep 19, 2008 04:31 PM
husky100
Jan 3, 2008 05:03 PM
Evlampius
May 29, 2005 10:58 AM
Tonyride
Mar 1, 2005 09:23 AM
