Yo people need help
Old Sep 12, 2016 | 07:09 AM
MisterG23's Avatar
Default Yo people need help
Hey everyone I just switch out my clutch now I can put it in gear I did everything correct n bleed the clutch n still won't go I gear stuck don't know what to do now so I need help
Old Sep 12, 2016 | 07:01 PM
If slave cylinder is not moving, you have a hydraulic problem; bad master cylinder, clutch cylinder, or air in lines.
If slave cylinder moves full travel, you have a mechanical problem in the clutch housing (bad news!).
Old Sep 13, 2016 | 03:53 PM
The Toecutter's Avatar
I agree with TexasHonda. Just so you know, you need 2 people to bleed the hydraulics. I did that last month on my 97 Accord, when I replaced both the clutch master and slave (master was just starting to leak into the car). It also allowed me to get a little more pedal height (engagement off the floor), as I was having an issue with that.
South
Sep 19, 2022 12:58 PM
Zachb11
Sep 13, 2015 08:27 PM
Levibyz
Jun 12, 2011 01:37 PM
fuller911
Jan 27, 2006 11:28 PM
Alex2053312
Apr 12, 2005 06:20 PM
