Sensor for Air Intake - Check Engine Problems
Old Apr 8, 2012 | 04:18 PM
TyWoz91's Avatar
Default Sensor for Air Intake - Check Engine Problems
Looking to put in a after market ram intake on my 04 accord lx but when I disconnect the sensor my check engine comes on. Any way to get past this?
Old Apr 8, 2012 | 08:31 PM
grim_reaper's Avatar
yeah put the new short ram in.. hook up everything properly, then simply reset the CEL by disconnecting the battery for a minute from the car..
Old Apr 9, 2012 | 08:37 AM
TyWoz91's Avatar
Thanks for the reply, so do I take out the old intake manifold like I normally would and unscrew that sensor piece and then leave it just dangling? I've never really had to deal with sensors. Also I'm thinking about the weapon R dragon air. What do you think?
Old Apr 9, 2012 | 09:15 AM
So there is a sensor on your stock intake that is not on the aftermarket one? It really has to be there, or you are going to get a CEL.
Old Apr 9, 2012 | 03:37 PM
Well, as far as what you're talking about there should be a little hole on the new intake that you get.. It may be plugged with something plastic, remove the thing, there'll be a hole and hook up the sensor into the hole..
Old Apr 10, 2012 | 12:15 PM
TyWoz91's Avatar
Ok sounds good. Thanks guys, I'll let you know of I find something else out.
Old Apr 11, 2012 | 02:48 PM
And beginning in 2003 with non-volatile memory, you can't reset your ECU by pulling a fuse or disconnecting the battery.
pondrun
Nov 8, 2021 09:40 AM
bcd127
Jul 22, 2013 01:32 PM
mjr.bonez84
Nov 22, 2010 08:49 PM
petef23a
Dec 14, 2009 08:23 AM
gabelmatt
Aug 25, 2005 10:21 PM
