F23A Turbo question. how much boost?
Old May 15, 2008 | 02:13 PM
SKHEMR's Avatar
Default RE: F23A Turbo question. how much boost?
I have crower conn rods, cost me $750. Go with Eagle Rods for about $400.
Aries pistons $650 custom made 87.5mm. Go with J.E. or CP piston. Aries are a little noisy.
The crankshaft can support 600hp
I still can't find a cam shaft but the stock is ok.
I can't remember what type of valves & springsI have.
Old May 15, 2008 | 02:17 PM
SKHEMR's Avatar
Myhonda has been parked so long because I drive the S14 more. Until it broke down. (Spun a main bearing and I need another crankshaft). The turbo power onthe 240is so much smoother, where the honda has a bit of turbo lag.
Old May 15, 2008 | 02:49 PM
KevinAccord's Avatar
thanx man! what's the S14 HP? and theAccords?
Old May 15, 2008 | 04:05 PM
SKHEMR's Avatar
S14 @12.5 boost felt about 240hp, the maf sensor stock is only good for 250. I will about to add bigger injector and a 300zx maf sensor and try to get 280 until the spun bearing thing happen. So I never got it dyno'd.
The Accord was at 238whp and 267 torque @9lbs of boost. I was shooting for 300. But when the vtec kicks in it goes from 140 to 238hp and you can feel it. So I was happy.
Old May 16, 2008 | 11:20 AM
cooooool!!!!! so, @ what rpm does your vtec open? im trying to see which rpm works best for me....(to engage vtec)
Old May 16, 2008 | 04:54 PM
SKHEMR's Avatar
3600rpm
Old May 23, 2008 | 11:27 AM
  #17
thanxs dude... mine was at 3900.... gonna try that one... and it stops @ 3500 right?
Old Oct 20, 2009 | 06:59 PM
  #18
boosted cb7
Default hey i need help
can you tell me if someone sells stuff to build a f23a for boost like head studs,gaskets,pistons,rods and more
Old Oct 27, 2009 | 11:08 AM
  #19
depends on where you live... where will that be?
Old Nov 6, 2009 | 10:28 PM
  #20
vSICK02
angelillo98
Apr 13, 2015 12:00 AM
streetlimitz89
Jan 27, 2013 11:50 PM
gio23
Apr 24, 2011 08:22 AM
micra
Aug 8, 2010 06:19 AM
sUbLiMe96
17
Oct 31, 2008 11:53 AM
