The primary function
Old Nov 24, 2009 | 06:02 AM
sharkee
Default The primary function
The primary function of the intake manifold is to evenly distribute the combustion mixture (or just air in a direct injection engine) to each intake port in the cylinder head(s). Even distribution is important to optimize the efficiency and performance of the engine. It may also serve as a mount for the carburetor, throttle body, fuel injectors and other components of the engine.
NO SPAM
Received Warning
sharkee
Default Turbulence
Turbulence
The carburetor or the fuel injectors spray fuel droplets into the air in the manifold. Due to electrostatic forces some of the fuel will form into pools along the walls of the manifold, or may converge into larger droplets in the air. Both actions are undesirable because they create inconsistencies in the air-fuel ratio. Turbulence in the intake causes forces of uneven proportions in varying vectors to be applied to the fuel, aiding in atomization. Better atomization allows for a more complete burn of all the fuel and helps reduce engine knock by enlarging the flame front. To achieve this turbulence it is a common practice to leave the surfaces of the intake and intake ports in the cylinder head rough and unpolished.
NO SPAM
Received Warning
Old Nov 24, 2009 | 06:03 AM
sharkee
Default Variable Length Intake Manifold
Variable Length Intake Manifold (VLIM) is an internal combustion engine manifold technology. Four common implementations exist. First, two discrete intake runners with different length are employed, and a butterfly valve can close the short path. Second the intake runners can be bent around a common plenum, and a sliding valve separates them from the plenum with a variable length. Straight high-speed runners can receive plugs, which contain small long runner extensions. The plenum of a 6 or 8 cylinder engine can be parted into halves, with the even firing cylinders in one half and the odd firing cylinders in the other part
NO SPAM
Received Warning
Old Nov 30, 2009 | 08:32 PM
KevinAccord's Avatar
please stop this... is there any way to sue ppl for this ads?
Old Nov 30, 2009 | 08:44 PM
Thumbs down #2 Spam
Thank You Jim for doing him in ..Spammer He Be
Clik Da Pik
Old Nov 30, 2009 | 08:59 PM
That poster is a
Old Nov 30, 2009 | 09:02 PM
Thumbs down Spam Post #3
Shame on you ...Bye ,Bye for a few days..Jim sent you packing...
CheriMo0n
Nov 14, 2016 06:14 PM
compiler
May 26, 2011 02:42 PM
deputystoneman
Jan 28, 2011 11:48 AM
efster420
Mar 7, 2010 02:31 PM
klyphman
Oct 12, 2006 04:43 AM
