Broken suspension part - Is it safe to drive?
Old Mar 16, 2015 | 07:32 PM
NorthCountry's Avatar
Default Broken suspension part - Is it safe to drive?
I have a 1998 Accord EX v6 3.0L.I changed the oil over the weekend and notice a suspension component that was so badly corroded that it actually broke in separate pieces in 2 different places.I could move the pieces slightly with just my fingers.See photos.
I don’t know what this part is called or its exact function but I want to know if it’s safe to continue driving the car?It must have something to do with the suspension/steering system but I never noticed anything driving the car.It drives and steers fine.If I wouldn’t have noticed it changing the oil I wouldn’t have known the difference.It actually could have been like this for a while.The same arm on the driver’s side is in much better shape than this one.
It’s so badly corroded I don’t know if it’s even replaceable.But what I first want to know is if it’s safe to continue driving the car or if I’m risking losing the wheel or something else very unsafe?
Thanks for any insight.
Attached Thumbnails Broken suspension part - Is it safe to drive?-100_1.jpg   Broken suspension part - Is it safe to drive?-1.jpg   Broken suspension part - Is it safe to drive?-2.jpg   Broken suspension part - Is it safe to drive?-3.jpg   Broken suspension part - Is it safe to drive?-4.jpg
Old Mar 16, 2015 | 07:33 PM
Here's a couple more photos...
Attached Thumbnails Broken suspension part - Is it safe to drive?-5.jpg   Broken suspension part - Is it safe to drive?-6.jpg
Old Mar 17, 2015 | 08:39 AM
Piece is the front beam and supports steering and engine. Do not drive IMO!
It can be replaced but engine will need support to perform replacement.
Old Mar 19, 2015 | 09:52 AM
Thanks for the response. That part is expensive and I don't know if the value of the car justifies the expense of the fix. I'll have to see what I can figure out with this one. Thanks again.
Old Mar 23, 2015 | 07:19 PM
Corvair's Avatar
I would not drive it.
Old Mar 25, 2015 | 10:26 AM
Thank you.
Old Mar 25, 2015 | 10:51 AM
shipo's Avatar
If the rest of the car is in good shape I'd say fix it.
Old Mar 27, 2015 | 06:11 PM
From a bone yard I'll guess the part is ~$300. There is a debate about the bolts, yet how many have removed/loosened those bolts to change the trans and never replaced them so I'm in the re-use camp.
If you repair, I'd doa bit of work on the used/new one before install. Clean the area's on the new one where the old one rusted away. A good coat of paint....and then just be but some spray undercoating. Make a few ref marks where the old one and the body are (outline) then when the new one goes in get in inside those marke.....then enjoy the ride.
Old Mar 28, 2015 | 02:58 PM
Thanks guys. I have one coming from the southern US supposedly in excellent shape with no rust. If I want it after looking at it, it'll be $225. I don't have all the tools or knowledge to do a job this big myself so I called a mechanic I know pretty well who said he'd give me a hand and let me use his shop for $400. Hopefully the part is in as good of shape as they say and we can get it in without having major issues. I didn't think a total of $625 was too bad for a job this big.
Undercoating will definitely be going on the new part Thanks for the suggestion.
MessAround
Sep 24, 2013 06:44 AM
powerslave
Jul 31, 2012 03:09 PM
Nitehawk Girl
May 9, 2012 02:54 PM
ajsanantonio
Feb 23, 2012 06:46 AM
thedaveman89
Jan 12, 2009 05:59 AM
