Coil overs or air shocks
Old May 12, 2013 | 12:35 AM
Dmayjah's Avatar
Question Coil overs or air shocks
Where can I get Coilovers for my 2008 accord lx. I see them for older accords and civics. Also can I put air shocks on it to lower it and adjust ride height
Old May 12, 2013 | 03:08 AM
hondafreak91c's Avatar
I think you are a bit confused. A true coilover is height adjustable, but you have to do it manually.
Air ride is a totally different setup.
Old May 12, 2013 | 07:54 AM
Dmayjah's Avatar
That's true I was asking which is better in terms of adjusting it for ease and look. I was told I can't put air shocks on a Honda but I think I I find the right suggestion I'll go with coil overs
Old May 13, 2013 | 04:25 PM
You can do air ride on a Honda. I have plenty of friends who have it. It is expensive though....not only do you have the air struts, you have to have compressors, the control switches, air lines........in all you will spend at the very least probably $2500.
I would personally go with coilovers. There are plenty of setups for your car. Just do some research.
-Koni Yellows/Ground Control coilover sleeves
-Function&Form Type 1 or Type 2
-D2
-KW
-Tein SS
-Tanabe Sustec Pro
-KSport
Old May 14, 2013 | 07:05 AM
Dmayjah's Avatar
-D2
-KW
-Tein SS
-Tanabe Sustec Pro
-KSport
Yep I've been researching and the best results come up for older Hondas but i will keep looking!
Old May 14, 2013 | 09:56 AM
Question A Little Info Please
Do you have a 4cyl or a 6 Cyl.
It makes a difference in fit.
Old May 14, 2013 | 01:34 PM
Just search on eBay. 90% of the time, eBay is the place you find them cheapest.
For example....I searched "2008 honda accord tein ss" The first result is the correct item.
2008 honda accord tein ss | eBay
Just do that with the other suspension options (some may not be made for your car), but that will give you an idea of the price.
Oasis
Oct 17, 2013 01:53 PM
jhungalmunkee
May 8, 2012 03:15 PM
accords own
Nov 14, 2007 02:19 PM
thunder_x
Apr 26, 2006 02:11 PM
19accord95
Feb 11, 2006 02:06 AM
