View Poll Results: How do you like the height of the Eibach Pro-Kit on this car?
Too Low
0%
Just right
55.56%
Still too high
44.44%
Voters: 9. You may not vote on this poll
Eibach Pro-kit + Koni STR.T -- 96 4dr EX
Old Aug 15, 2012 | 10:28 AM
jkowtko's Avatar
Almost A Senior Member
Default Eibach Pro-kit + Koni STR.T -- 96 4dr EX
I just finished swapping out the stock suspension on my son's Accord and thought I'd post the before and after pics so you can see the difference:
They're a tad low for my liking, but I got the springs at a really good price (new/other) so I'm not complaining. The car was so high initially I didn't know how much the Pro-Kit would lower it. If I had my choice and cost wasn't a factor I would probably swap out the springs for the higher H&R OE Sports.
The Koni STR.T shocks seem like they would be a bit soft, however the suspension is very stable and level around corners and braking. I'm happy with them, although I wonder if the cheaper KYB GR-2s would have been about the same.
Fyi, the tires are 215/45-17 with medium wear.
Next up is to comb through the remainder of the suspension looking for noises. Evidently when you put a new (and stiffer) set of springs and shocks on a tired and worn suspension it brings out all of the other issues. On the front I've already replaced the front upper control arms and sway bar bushings, might need to do the lower ball joints next. On the rear I haven't replaced anything else yet, might start with the sway bar links and then start going through the bushings. If anyone has suggests on the order in which to do your advice would be appreciated.
Old Oct 12, 2012 | 02:04 PM
MichelAC's Avatar
I think it looks just right.
Old Oct 14, 2012 | 12:55 AM
I like it lowered..all my cars have always been lowered..thats the look I like the most..
Old Jan 16, 2015 | 03:41 PM
jkowtko's Avatar
So it's been a couple of years now, the fronts feel good, but the rear suspension seems horribly underdamped on compression. If I hit a sharp dip in the road the rear end feels like it drops considerably. I prefer a stiffer feel.
Has anyone out there used the combination of Pro-Kit springs and STR.T shocks, who can comment on this behavior?
Thanks. John
Old Jan 17, 2015 | 11:42 AM
Let's see what comes up with your question..
jkowtko
Mar 8, 2015 09:20 AM
Whitefoxx
Mar 10, 2009 07:51 PM
glen e
Mar 5, 2009 03:58 PM
thunder_x
May 6, 2006 04:33 AM
ONEwickedACCORD
Nov 11, 2005 03:02 AM
