Full System
Old Feb 2, 2008 | 11:56 PM
BuntinBoy9's Avatar
Default Full System
Ok so here is the deal i think i might want to lower my 94 4cyl accord with the skunk2 sportschock and adjustable coilovers... now here is the ?'s i want to prolly lower the front more than 2 in and the rear at 2in so will i need to get an adjustable camber kit to go with them and if so which one is best to go with and also i want to put these on myself but i dont know what i need to have or do. do i need to have a spring compresser or what? im completly new and am still learning about suspension i know sum stuff but not enough to pull this off but give me as much advise as u want because i want and need it!!!!! Thanks
Chris
Old Feb 4, 2008 | 10:07 AM
thunder_x's Avatar
Default RE: Full System
spring compressor, jackstands, jacks, wrenches, screw drivers, flash lights, and a few people to help you out would be really nice.
it would make the job a lot quicker, easier, and funner.
Old Feb 4, 2008 | 10:14 AM
sir_nasty's Avatar
Ingalls makes a commonly used camber adjustment kit.... Read through "Suspension 2.0" (post stickied to the top of the suspension section) also, check out a few of the suspension posts in the DIY section
Old Feb 4, 2008 | 01:48 PM
falkore24's Avatar
Old Feb 4, 2008 | 03:15 PM
BuntinBoy9's Avatar
alrighty i checked the 2.0 thing right after i posted and found out a lot of stuff i just wanted to know if anyone had done it themselves and how much time and what did it take to do it. THANK YOU
Old Feb 4, 2008 | 05:04 PM
sir_nasty's Avatar
Your first time doing it you should plan on 8 hours (in case you hit problems) but most likely you're going to be at it for 4-6 hours. As for what it takes to do it Thunder_X had a pretty good listing. Ideally you want 10-19mm sockets in both standard and deep well, along with two different lengths of extensions, Open ended wrench set, spring compressor, jack-stands, wheel blocks, A jack, WD-40 (in case a bolt doesn't want to come loose), Instruction/Service Manual (www.hondahookup.com/manuals/), A big piece of cardboard.
Cardboard: When you remove the old setup make a brief outline of where the lower forks are in relation to where the bolts on the cap are, that way when you assemble your new setup you won't have to fight it as you put it into the car. If the top isn't aligned with the bottom properly then one of them isn't going to line-up with the bolt locations in the car.
Old Feb 5, 2008 | 05:34 PM
falkore24's Avatar
you forgot the breaker bar!!!!! Definately one of my favorite tools!!!
faran
Jul 25, 2013 08:48 AM
K3L
Feb 20, 2013 10:44 PM
oman510
Jul 31, 2009 06:35 PM
Texas4Banger09
Apr 8, 2009 07:05 PM
sajeed
Jul 3, 2008 12:36 AM
