tie rod boots
Old May 12, 2011 | 09:32 PM
Tek310's Avatar
Default tie rod boots
what do you guys think about these?
Energy Suspension 9.13103G Tie Rod Dust Boot Set | eBay
Old May 13, 2011 | 04:37 AM
ronjr8102's Avatar
they probably would prevent premature drying out and cracking and leakin grease. IMO not worth the work to put them on unless ur already gonna replace the tie rod ends. What would be the real overall potentional of them?
Old May 13, 2011 | 06:59 AM
Only place I could see them is over the end of the tie-rod dust boot. That boot is a dust cover for the inner tie-rod ball jt and end of steering rack. All the boots I've had fail split in the middle of the boot, not the ends.
Maybe I'm missing something but looks to be worthless IMO.
Old May 13, 2011 | 11:22 PM
Those look like replacements for the rubber boot that comes on the tie rod. Not worthless, but it's a replacement part. Doesn't go over the existing boot but replaces a torn original.
Old May 14, 2011 | 03:27 AM
ronjr8102's Avatar
but once ur original boot splits and u lose grease/get in water/dirt then the joint is on its way to failing. Even if u replace a split on eventually it will go bad and need to be replaced
Old May 14, 2011 | 08:05 AM
If it's meant as a tie-rod ball joint boot, I've seen these and they are poorly designed substitute for the OEM ball joint boot. Problem is they have only a tiny ridge as a retainer which will allow water and dirt to enter the ball joint.
MichaelT1960
Jun 3, 2014 02:16 PM
ArcticHonda
Feb 17, 2007 02:57 AM
Tony1M
Jul 3, 2006 08:12 PM
aka1109
Jan 10, 2005 02:19 PM
