5 lug conversion
Old Jun 26, 2013 | 04:02 AM
CG5Kyle's Avatar
Default 5 lug conversion
How difficult is it to do a 5 lug conversion on a 1999 Honda Accord Ex 4cyl and what would I need to do this? Any information would be helpful, thank you.
Old Jun 26, 2013 | 07:13 AM
In the rear you should get away with just the 5-bolt hubs & corresponding brake rotors. Check a parts place to see whether the caliper has a different part #, but I think they are the same.
In the front, get hubs & rotors also, but removing the hub from the steering knuckle will probably destroy the wheel bearing. Check the brake caliper part #s also.
The reason I say check the calipers is I think(?) the 5-lug brake rotors are the same diameter, but I'm not absolutely sure.
Old Jun 26, 2013 | 03:15 PM
CG5Kyle's Avatar
Will do, thanks.
01Accord01
Dec 28, 2014 03:49 PM
joelluv12
Mar 25, 2009 06:44 AM
HORSEPOWERJUNKIE2007
Sep 2, 2008 08:02 PM
jkellyre
May 15, 2007 07:39 PM
Tommy997
Jul 26, 2006 02:14 PM
