Wheels/Tire size for 1983 Accord
Old Sep 23, 2012 | 10:25 PM
chrishead's Avatar
Default Wheels/Tire size for 1983 Accord
Looking to upgrade wheels on my '83 Accord Hatchback but worried about getting something too big. Getting a lot of noise from one of them and i think either the wheel is bent or need to change the bearings. Anyway...
Current wheels (original 13"x5"/+45 offset steel wheels) look to be a perfect fit. Gap between the edge of the tire and the cover of the coil spring is the size of my pinky. Afraid of upgrading to anything bigger... So wanted to double check and get some suggestions.
Want to upgrade to this wheel and maybe some smaller tires:
Rim Width 5.5
Bolt Pattern 4x100
Rim Diameter 14
Offset +45
Thanks.
Old Sep 24, 2012 | 04:33 PM
Talking Hello New Member
Thank You for joining and for your 1st post..Make sure you put it in a forum that goes with your questions next time.
This link will help you with your question ..give it a try.
https://www.hondaaccordforum.com/for...ator-your-use/
Attached Thumbnails Wheels/Tire size for 1983 Accord-348683-w170.jpg
Old Sep 25, 2012 | 05:29 PM
chrishead's Avatar
Thank you sir. Hopefully that calculator is accurate.
outrigger
Feb 25, 2012 08:01 AM
bostonbeans
Mar 9, 2011 12:21 PM
tumminello123
May 23, 2010 01:44 PM
fdunlap
Sep 18, 2008 07:10 PM
DDTG_ACCORD
Apr 29, 2005 05:23 PM
