Will 22" rims fit on a Accord LX Coupe?
Old May 14, 2009 | 05:38 PM
FaTaL-
Default Will 22" rims fit on a Accord LX Coupe?
Alright I know this sounds crazy, call me that if you would like but basically I have a set of 22 inch rims that were given to me by my dad I had plans on putting them on a truck but instead I brought a 2001 Accord LX Coupe and I'm wondering if these rims would fit on it probably would look outrageous but o well.
Thanks in advance.
Old May 14, 2009 | 05:50 PM
19Accord97
First you need to make sure the bolt pattern and offset will work!
Other than that, you can make it work by rolling the fenders or lifting it! Check on cardomain.com and see if any other accord of your gen have 22's
Old May 14, 2009 | 06:03 PM
FaTaL-
Thanks, Fast Reply.
Old May 15, 2009 | 04:50 PM
draser's Avatar
Hey, anything's possible - but why.....
Old May 15, 2009 | 04:52 PM
FaTaL-
Just because, but anyways I should have checked this before I posted this thread the honda is 4 lugs the rims are 5 lug nuts so o well. Guess Ill get some 20" s or something. Thanks again.
Old May 15, 2009 | 05:56 PM
Talking * If Your Interested *
If your interested in something smaller...say 20" then here are some dimensions
for you to look at.
Plus 20 specs are ...Tires: 225/30/20, Wheel hub: 64.1mm , Off Set:35-42mm
Your overall OutSide Diameter for stock wheel and tire is 24.7"
Your overall Outside Diameter for the 20" will be 25.3" so you see there is hardly any problem on the overall diameter which would change your speedometer , ABS , or computer controlled operations.
Attached Thumbnails Will 22" rims fit on a Accord LX Coupe?-imagesymbolicwheels09.jpg
Old May 26, 2009 | 01:26 AM
MagicOPromotion's Avatar
im going to cal the guy tomarow and probably drive down town to look at them and check if they fit. i have a feeling the tires will be small, but i can just take the tires of the stock rims and use them right?
deerdawg
Feb 9, 2025 10:59 AM
joenintiesc
Apr 14, 2013 07:29 AM
ysbarney
Oct 1, 2012 06:04 PM
Reggi's-accord
Jun 6, 2012 07:17 PM
HondaAficionado
Nov 30, 2010 05:24 PM
