2 pin oil pressure sensor
I have a UK 2002 1.8i Vtec sport and am trying to replace the oil pressure sensor but cannot find a similar to the one that needs replacing..
It's grey in colour, round, has no grooves and has 2 pins. The plug that goes with it is grey also and has a white internal..
Hope this makes sense to someone..
I'm not sure where I can find parts drawings etc for UK cars.
But one silly thought...
Are you talking about the VTEC oil-pressure switch? It's on the VTEC spool valve, located sorta between the head & the intake-manifold. (And it has a 2-wire connection.) The oil-pressure switch (for the oil warning-light) is located on the back side of the block, just above the oil filter.
JimBlake is probably correct, that you're looking for the VTEC oil pressure switch, which is 2-pins.
The other oil pressure switch is only 1-pin, even on UK models.
You can find parts diagram at Lings Honda.
tattoodwaitress
06-23-2012 10:53 PM
ChicagoBob123
11-06-2011 06:22 PM
piconrule
07-24-2009 02:38 PM
