2 pin oil pressure sensor
Old Mar 13, 2015 | 10:30 AM
CoolUncle's Avatar
Default 2 pin oil pressure sensor
I have a UK 2002 1.8i Vtec sport and am trying to replace the oil pressure sensor but cannot find a similar to the one that needs replacing..
It's grey in colour, round, has no grooves and has 2 pins. The plug that goes with it is grey also and has a white internal..
Hope this makes sense to someone..
Old Mar 13, 2015 | 12:08 PM
I shall move to Genl Tech for you..
Welcome to the HAF..
Old Mar 13, 2015 | 12:35 PM
CoolUncle's Avatar
Cheers for that..
Old Mar 13, 2015 | 01:14 PM
I'm not sure where I can find parts drawings etc for UK cars.
But one silly thought...
Are you talking about the VTEC oil-pressure switch? It's on the VTEC spool valve, located sorta between the head & the intake-manifold. (And it has a 2-wire connection.) The oil-pressure switch (for the oil warning-light) is located on the back side of the block, just above the oil filter.
Old Mar 13, 2015 | 01:28 PM
JimBlake is probably correct, that you're looking for the VTEC oil pressure switch, which is 2-pins.
The other oil pressure switch is only 1-pin, even on UK models.
You can find parts diagram at Lings Honda.
pondrun
Nov 8, 2021 09:40 AM
tattoodwaitress
Jun 23, 2012 10:53 PM
jerrym
May 16, 2012 06:51 PM
ChicagoBob123
Nov 6, 2011 06:22 PM
piconrule
Jul 24, 2009 02:38 PM
