1994 accord stereo problem. Help!
Old May 31, 2006 | 06:27 AM
coupe_hybrid
Default 1994 accord stereo problem. Help!
I just installed a aftermarket cd player into my 94 ex accord and realized that the memory wire coming from the stock radio harness is dead. Anyone know how I could fix this problem? Right now I'm running the cd player by connecting the power wire and memory wire together and it sucks cause I have to adjust the settings everytime I turn on the car.
Old May 31, 2006 | 02:48 PM
sir_nasty's Avatar
Default RE: 1994 accord stereo problem. Help!
start by tracing the memory wire and see if you can find the break for starters... if not fine a constant lead that is on no matter what ( I believe your cigarette lighter will work nicely for this) and tap into it
Old May 31, 2006 | 05:25 PM
jtf4619's Avatar
First thing you need to do is check the fuses for the radio. Most of the time it is the 7.5 amp radio fuse underneath the hood, but i don't remember if it is the constant fuse. If not this, then check the fuse inside the vehicle. If both these fuses are good then you have to run a new constant wire. Im pretty sure the cig. lighter is not run on constant power, but whenever i have to run a new constant wire for a deck on these vehicles, i go to the fuse box inside the car. There are 4 or 5 male spades underneath all the fuses. One is constant, another is switch, another is parking lights and dunno what the others are. Just test the spades and connect a female spade to it and run it to the radio.... problem solved
Old May 31, 2006 | 08:07 PM
coupe_hybrid
I've checked both fuses and both of them work. I'll try to find a constant power supply and run a new wire. Could I tap into the power seats? Isn't that a constant power supply?
Old May 31, 2006 | 08:38 PM
sir_nasty's Avatar
In some cars it is but you'd need to test it to be sure... the best way to do it is run off the fuse block like someone said earlier... or you could get crazy and run a line straight off of your battery *L* (I've seen that one done before too...) have you tested the lead with a volt meter to make sure that it is in fact dropping/loosing voltage when the car goes off?
Old Jun 1, 2006 | 03:47 AM
coupe_hybrid
Yeah I've tried checking for voltage when the car is on and off and get nothing.
Old Jun 4, 2006 | 11:23 AM
spectre184's Avatar
coupe_hybrid have you got it fixed yet? If not I JUST happen to have a Mitchel print out of stereo diagrams for your car. My step daughter has same one
Any way I could scan in Adobe and e-mail them to you. I just need to know if you have premuim or base radio. Premium has tweeters up in corner of dash.
Let me know or PM me your e-mail!
pollyboy001
Mar 27, 2012 07:23 PM
phr3shaccord
Oct 18, 2011 12:00 PM
Dr. Funkenstein
Aug 14, 2011 09:58 PM
JimboBigLotto
Jul 2, 2011 01:46 PM
jeremyrudko
Feb 25, 2008 05:12 PM
