2000 Honda Accord Ex Coupe
Hi, I'm working on my brother's 2000 Honda Accord Ex Coupe. I finally got the radio working after I figured out where the passenger side fuse box (3rd box I checked :-)) is and replaced the fuse. I got the code for the radio and its working. However, the Power Outlet(same fuse) is not working. I took it all apart and surprise, there is no wire at all connected to it. To make matters worse, I see no cut wires or places where wires would run to/plug into. I've got the whole center console out and can see all the wires up to the radio. I know I can probably just tap into the red wire for the radio and run a ground wire, but was hoping to keep it as neat and unmolested as possible. Is there an accessory wire/harness that should plug into the main/radio harness for the 'Power Outlet? Or did somebody just cut the wires near the harness? The radio is stock and most everything else is stock - at least as far as the dashboard/radio and electronics are concerned.
Thanks for any help...
Ok, I found it :-) Somehow whoever worked on this car last tucked the two-wire harness branch that leads to the power outlet between the edge of the driver's seat and the carpet that runs under the center console -- it didn't help that the driver's seat has a cover on it that eliminates any gap between the seat and that carpet. Anyways, it's all connected now.
Casey Lembo
Oct 1, 2020 07:00 PM
shoop513
Jun 26, 2013 09:40 AM
