Fog light help
Old Mar 15, 2009 | 06:31 PM
MikeyMike's Avatar
Default Fog light help
I bought fog lights for my coup v6 05 accord and i connected all wires like it said but theres like three wires i cant find where to plug in. So my question is, can i just split the wires and tap into the headligth so they turn on with the head lights? if so how do i do i t i tried and they turned on but they dont turn off when i turn the lights off can anyone who has tried this please give me feedback. i need help
Old Mar 15, 2009 | 08:00 PM
finch13's Avatar
Old Mar 15, 2009 | 10:38 PM
cjdm98's Avatar
I had mine wired to a fuse that only worked when the key was in Acc.
Old Mar 15, 2009 | 10:40 PM
MikeyMike's Avatar
where was the fus in the engine or under the stering whell
Old Mar 15, 2009 | 10:42 PM
cjdm98's Avatar
Under the steering well. Dont remember what fuse i ran it to,but have a multi meter in hand,turn the key,and find out what works when the key is turned,you want to get the power source away from the battery.
MikeyMike's Avatar
i tried that pdf file on how to install but i still had 3 wires harnesses that didnt go anywherre i spent hours looking for them but i have an 05 and they just werent there i wanna just split them ito my headlights or a fuse that turns off when the car is off or headlight switch is off any recommendation? and which color wires do i use i have three of them anyone thats done this so the can show me how
Old Mar 18, 2009 | 06:39 PM
MikeyMike's Avatar
how would i splice the fogflight wires to put in the acc there are three wires which oine do i put on the fuse and where do i out the rest
Old Mar 18, 2009 | 06:40 PM
finch13's Avatar
I honestly have no clue because I don't know if there are relays in the harness or not. If it doesn't work, you may have gotten the wrong part.
Old Mar 18, 2009 | 11:55 PM
cjdm98's Avatar
The (red?) wire that you would have probably run to the battery as a source of power should be wired to the fuse.
Dude your making this seem complicated,the installation is simpler than a radio install..Which you seem to know all about.
Old Mar 19, 2009 | 12:01 AM
t00fatt's Avatar
3 Wires or harnesses? Prolly three wires to hook up a relay....
If not just trace the wires see whats going on and make it work, being a big shot installer you shouldn't need any more advice than that. Halogens are not polar so just feed them a current, switch it, and call it a day....
iownahonda
Apr 18, 2013 06:21 PM
flyboy7588
Oct 11, 2011 11:40 AM
99accordkrueg
Aug 10, 2011 10:12 PM
guru350
Feb 18, 2011 07:34 AM
jjhu00
May 27, 2007 11:56 PM
