Honda Electrical Load Detection (ELD) Bypass
Old Apr 15, 2012 | 10:59 AM
  #51
keep_hope_alive's Avatar
yes, true for any Honda.
Old Apr 15, 2012 | 02:53 PM
  #52
desk0amb's Avatar
yeh, perfect then haha, i'm gonna try the website you provide here to get the parts then, can't wait to do this.
BTW great thread! well explained.
Old Apr 15, 2012 | 03:10 PM
  #53
desk0amb's Avatar
just want be sure. are this the correct parts? my doubt is with the resistor.
this are the parts number at part express:
002-820
330-070
330-075
is that correct? i already have the switch and wires. i'm guessing any 12v switch would work right?
Old Apr 15, 2012 | 10:02 PM
  #54
Correct, those are the parts I used/recommend.
002-820: 820 Ohm 1/2W Flameproof Resistor
330-070: 12 VDC Tyco 5-Pin Relay SPDT 20/30A
330-075: 12 VDC 5-Pin Relay Socket For Bosch Type Relay
Yes, any non-lit 12VDC switch will work. The kinds with an LED are wired differently.
Old Apr 16, 2012 | 08:20 AM
  #55
desk0amb's Avatar
all right, perfect then, now gotta wait for the parts, thanks for the info again.
Old Sep 19, 2012 | 05:46 AM
  #56
Chris333's Avatar
Sorry to sound like an idiot, but I cannot find the ELO in my car. Here is the fusebox:
Can anyone point it out to me?
Thanks
Chris
Old Sep 20, 2012 | 01:22 PM
  #57
it may be UNDER the fuse box!
Old Sep 21, 2012 | 04:27 AM
  #58
Chris333's Avatar
Ahh found it under the fuse box...
OK so I want to permanently cut out my ELD.
I just unplug the connector and jump the ground and ECM lead with the resistor, correct?
Thanks
Chris
Old Jun 30, 2013 | 05:14 PM
  #59
Honda neophyte's Avatar
Default ELD or no motor ground!!
Im having electrical problems when running lights and a/c. I had a buddy scan it 12.75v was average and hit bottom around 10v. We checked alt. and battery both showing 14.09v. He was saying the ecm wasnt grounded to motor when it was replaced. Could it be no grounds on motor and eld or both?
Btw I gotta 97 accord lx 4 banger.......Oh yeah wheres the eld located?
I also forgot to mention my thottle cuts out when running a/c and lights. Everything checked good on scan except voltage
Attached Thumbnails Honda Electrical Load Detection (ELD) Bypass-img_20130630_161206_730.jpg
Old Jul 2, 2013 | 11:52 PM
  #60
the small wires in the bottom right are the ELD wires. the ELD is under the fuse box.
motor grounding is paramount. upgrade engine block to chassis ground.
