05 v6 tranny in a 98 car
Old Jan 10, 2006 | 02:17 PM
avs0730
Default 05 v6 tranny in a 98 car
i was wonder if the v6 tranny out of a 05 coupe will fit in 98 v6 4 door. i think the 05 has a 5 speed auto if so how can i make it work
Old Jan 10, 2006 | 09:23 PM
avs0730
Default RE: 05 v6 tranny in a 98 car
i guess not or nobody knws
Old Jan 11, 2006 | 03:47 AM
lightshow's Avatar
i thinking the bolting pattern is the same, but the transmission control unit is completely different. im sure it could be done somehow, but make no mistake it would tax the limits of even the best mechanic just because of how rarely it is done. the harness plug is probably completely different on the two models you may just want to clip it. then if you are good at wiring you could put it all back together, you would need a wiring diagram and a multimeter, the two trannies work on the same principal. speed, load, incline, throttle position sensor, etc. my advice is to get a period correct transmission for your car, even if it costs a little more money. theres nothing better than plug and play
lightshow
Old Jan 12, 2006 | 12:32 AM
avs0730
thanks your right
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
eric123
Apr 21, 2008 09:27 PM
shawn till dawn
Jan 24, 2007 04:34 PM
