2.2 vs. 2.7 Worth It?
Old Dec 22, 2007 | 01:55 PM
  #31
BlkCurrantKord's Avatar
Default RE: 2.2 vs. 2.7 Worth It?
Power to weight ratio
Civic's and teg's have the advantage. We just need more power than them. That's why we get 2.0L and larger motors.
Old Dec 22, 2007 | 05:49 PM
  #32
wingedwonder69
if everything about my post is sooo wrong how come all of it came out of a reputable honda tuning book. research before you speak
Old Dec 22, 2007 | 06:21 PM
  #33
ORIGINAL: wingedwonder69
Since you asked.
ok the main thisg here is that if you want to run a turbo and nitrous you will first need to weld supports in the space between the block and the cylinder sleeve caus if you don't that sleeve will wander and you could have issues, that is if you are set on sticking with the f22 motor. the best option and maby the cheapest would be to order a jdm motor for an early 90's body style accord sir-t with an ecu. The sir-t motor that came in those was a turbo 2.3L. of course you will need to upgrade the turbo on the new motor as well as an intercoller. that could be enough right there, but who knows i could be drunk!!!!!!
Ah yes...weld in supports so the sleeves dont walk. Ya umm..you know how often that happens? He'll blow piston rings or melt a piston before he ever gets cylinder walk.
Let me check on this early 90's sir-t you speak of. Oh hey, it doesnt exist. In fact, honda never had a factory turbo motor until the RDX, and guess what, its a 2.3L K series.
Someone besides me needs to be doing the researching. I've done my fair share.
Old Jan 1, 2008 | 08:40 PM
  #34
honda97valdeez's Avatar
BCK- Damn I wish you were a v6 owner![&:]
Old Jan 1, 2008 | 09:50 PM
  #35
ORIGINAL: honda97valdeez
Why?
thunder_x
Oct 15, 2006 10:33 PM
saad180
Apr 2, 2006 01:39 PM
lightshow
Jan 16, 2006 10:56 PM
poliwog823
Dec 21, 2005 12:39 PM
arffam1
Sep 6, 2005 11:31 PM
