2004 2.4 Timing Chain?
Hi all,
I've got an 04' Accord EX 2.4L, with 160k miles. Im planning on replacing the timing chain /water pump when it warms up some. are there any timing chain sets anyone would recommend to get or to stay away from? Also, I've kept up with all the standard stuff (oil, filters, plugs) since I bought it at 32k miles. The only thing outside of routine maintenance ive had to replace is the starter & thermostat. Is there anything else that I should look into repairing/replacing at this point. The car still runs great, and I'm planning on looking over all the suspension parts when I replace the timing chain. I drive 100 miles Miles round-trip on a daily basis.
Thanks,
Thanks,
Hi all,
Thanks,
Thanks,
please correct me if im wrong.
But im not so worried about the chain, im more worried about the tensioner than anything, im worried the tenisoner will wear out causing the chain to increase slack causing the engine to be further and further out of time.
Now Im also not set on that logic because Im not positive if its the type of tensioner that once you set it, its set in place and can not wear out.
Another side of me is thinking I should go ahead and replace the water pump and while im there i might as well replace the timing chain.
A check engine light and code P0341 will be set by excess chain slack.
Google "Honda timing chain tensioner" for some interesting reading.
I suspect risk of damage/oversight doing such a preventive maintenance task far exceeds risk of closely monitoring engine and good maintenance practice.
I think I'm in this same situation but with a P0341 code. Car is running fine and I'm trying to figure out why the code keeps coming up. Everything points to the tensioner and stretched timing chain with my 2005 Accord 2.4L. Car is running fine an I don't want more issues.
Here's my post:
https://www.hondaaccordforum.com/for...-accord-64167/
Its good to hear that I don't need to do the water pump too. I did a belt change with water pump/oil seals on a 1995 Accord 10 years ago and it wasn't hard just took some time. The 2005 might be a little harder due to how tight it is....
Here's my post:
NoORs
Apr 4, 2015 01:54 PM
