2007 Accord oil change
Old Aug 13, 2009 | 12:30 PM
wolfehunter's Avatar
Default 2007 Accord oil change
So how do you guys keep oil from dripping down on the frame and edge of the oil pan when removing the old oil filter? Did my first oil change and tire rotation since buying a used Accord 2.4 liter last month. Any help appreciated.
thanks ,
scott
Old Aug 13, 2009 | 01:42 PM
It always dripped when I did it. I was just glad it wasn't dripping down my arm to the elbow like the F-series filters.
98 Accord:
Wrap newspaper under the filter, so the oil doesn't run onto the exhaust pipe & start a fire. So the paper touches the hot exhaust pipe & IT starts the fire.
03 Accord:
Position the drain pan so it catches the dripping oil. That part of the subframe stays oily so it doesn't rust.
Old Aug 13, 2009 | 05:46 PM
otsb708's Avatar
Almost A Senior Member
uh...what?
Old Aug 13, 2009 | 06:53 PM
19Accord97
I hate that!
Old Aug 14, 2009 | 09:19 AM
Originally Posted by otsb708
uh...what?
It was a dumb wisecrack. I never found a good way to prevent oil from the filter from dribbling down the block & dripping onto the subframe.
Old Aug 14, 2009 | 11:07 AM
lairdylairdy's Avatar
are you not able to just wipe the oil off with an old rag after changing out the filter? it's easier than trying to prevent a mess and making a bigger one
Old Aug 14, 2009 | 11:08 AM
just make sure you put the drain plug back in before adding the new oil, lol
my friend was pissed when he forgot and found all his oil runnin out his garage
Old Aug 14, 2009 | 12:22 PM
klrspz's Avatar
Good chance you'll never find a way...
On my 84 4Runner the filter was upside down, and just under it was a control arm, so it got EVERYWHERE...
On my saturn there was enough space to build a makeshift funnel out of an old milk jug to redirect the oil pour , but I haven't found a way to do that on the Accord and have space to remove it with your hand.
Old Aug 18, 2009 | 10:57 AM
That's why I asked. I also had a 98 Saturn that I fabricated an empty plastic one quart container of oil to catch the oil and redirect it into the oil pan without making a mess. It didn't make that much of a mess with the Accord and I had used an old rag to clean it up. Just didn't know if there were any "tricks" that you guys were aware of. Since I rotate tires every time I change oil I thought maybe a certain way I jack up the car might make less of a mess when draining the oil but none of the angles worked. Old rag works great!!
Old Sep 12, 2009 | 08:30 AM
hondaaccordtech
honda actually makes a engine oil filter drain redirector. i have 1 but the part # i do not know off the top of my head. go to your honda dealer and order 1 there...
PinkFloridaFlamingos
Aug 24, 2011 12:35 AM
chris h
Apr 3, 2011 10:01 AM
ziwang55
Jun 6, 2008 01:25 PM
Grail72
Aug 11, 2007 05:17 PM
