97 accord head gasket job
Old Apr 14, 2009 | 11:44 PM
acurlvr123
Default 97 accord head gasket job
my friends and i are pretty sure i have a blown head gasket. im not scared to rip one from a junkyard and do this project myself. i have the sohc non vtec engine and i have the dx model. i was just wondering if its as hard as everyone says it is. i welcome your tips and advice. thanks!
Old Apr 15, 2009 | 02:09 AM
19Accord97
Haven't done it but I am guessing it is not easy.
I would buy/go find a Chilton's manual. I have a Haynes, but haven't looked for head gasket replacement. Good luck!
Old Apr 16, 2009 | 06:55 PM
draser's Avatar
Did you run (and failed) a compression test, or you're losing coolant - see steam out of tailpipe, or the oil has foam in it?
Replacing the head gasket is an involved job b/c you need to remove "half of the engine" to get to it, then you need gaskets (head, exhaust/intake manifolds, etc), torque wrench and torque specs, may need new head bolts if they don't measure right, etc. Then you need to torque it right, put the manifolds back on, adjust the timing - speaking of which you'll have to remove the crank pulley bolt, there's plenty of material on this forum about that.
Also, if you want to run the tests for a failed HG, there's material on this forum.
zReizZLeS909
Jan 22, 2012 01:13 PM
82009_honda
Nov 26, 2009 09:17 AM
kris_loehr
Nov 9, 2008 03:47 PM
thunder_x
Jul 9, 2007 11:57 AM
dodins
Mar 18, 2007 08:10 PM
