A/C Problem
Old Aug 22, 2011 | 02:34 PM
brandonmorris's Avatar
Default A/C Problem
When I turn my key off, the air conditioner in my 95 Accord EX continues to blow out, I was told that the ignition switch may be bad, so I changed it, and it still does it. I was then told that the ac relay could be stuck, any ideas. Where is the relay for the ac on this vehicle.
Old Aug 23, 2011 | 10:43 AM
What exactly do you mean? Is the ventilation blower still running after you switch off the engine?
If you turn back to accessory position & run the blower, its normal for it to remain cold for a little bit. The evaporator & some other parts are already cold & they take some time to warm up to room temperature.
trouble
Aug 21, 2012 07:46 PM
jkrueger2020
Mar 10, 2011 02:18 AM
kellysa111
May 1, 2009 08:35 AM
mahones
Oct 13, 2008 08:24 AM
92Inspire
Aug 13, 2006 03:37 PM
