Cabin Noise
Old Oct 31, 2009 | 10:29 AM
mrjlbezner
Default Cabin Noise
I want to make the cabin more quiet on my 2009 EXL any suggestions.
Old Oct 31, 2009 | 11:26 PM
MacLeod's Avatar
Depends on how much work and money youre willing to put into it.
If youve got the place to do it and can spare a Saturday then pull out the seats and carpet and slap a layer of Dynamat Extreme along the floor and door panels. This will add mass and rigidity to your sheet metal making it much less susceptible to resonating from road vibrations. Then add a layer of DynaPad down. This will block the road and engine noise.
Its pricey but it works.
http://www.crutchfield.com/p_1542110...isplay=Dynamat
Old Dec 25, 2009 | 11:55 AM
tedmets
How much road noise would you eliminate if you used 1/2 inch Dynapad without a layer of Dynamat extreme? $140 for the Dynapad is a lot easier to take than $600 for the Dynamat Extreme.
I've got a 2009 EXL also and I can't believe how noisy it is. I thought maybe it was the tires (Michelin pilots), but my local tire store said they are good, quiet tires.
ccasey3655
Jul 7, 2010 08:02 PM
VZ2
Sep 3, 2009 12:25 PM
Dan the man
Feb 12, 2006 12:46 AM
alabamatoy
Jan 24, 2006 10:17 PM
ddwest8
Nov 22, 2004 03:29 PM
