Compression change
Old Sep 3, 2006 | 04:48 PM
lightshow's Avatar
Default RE: Compression change
id say bump it up to about 12:1 and run exclusively 166 octane. im not sure how much 116 costs now but the car would be absolutely unstreetable, but you would probably have close to 200 hp. or you could turbo, get about 22-24 mpg, run pump gas, and have about 220 hp
Old Sep 3, 2006 | 06:30 PM
ncsgoofy's Avatar
Well turbo would be slightly cheaper.
Another question, does a new flywheel make a big diffence?
Old Sep 4, 2006 | 05:10 AM
marbro's Avatar
leave it to you to suggest using gas thats over 10 dollars a gallon, turbo would be a little more then slightly cheaper to do a good na build you would be spending close to the crazy priced turbo kits that are over 3000 dollars but a lighter flywheel will help, but not 200 hp help that would be more in the area of better throttle response and a little more umph off the line.
Old Sep 4, 2006 | 03:04 PM
ncsgoofy's Avatar
With the flywheel, and above mentioned stuff, do you think i could see 140WHP
Old Sep 4, 2006 | 08:18 PM
marbro's Avatar
depending on the specific engine you have you may not be far from it, and a new cam will get you to the 140whp mark, which engine model is it? I know f22 but which is it beyond that? a1, a4, or a6?
Old Sep 4, 2006 | 09:01 PM
ncsgoofy's Avatar
Its the F22A1
Old Sep 4, 2006 | 09:04 PM
  #17
ncsgoofy's Avatar
I'll head to a Dyno soon, so i can get a "baseline"
62maxx
Oct 18, 2015 08:20 AM
KincaidChance
May 3, 2011 01:13 AM
chris h
Apr 3, 2011 10:01 AM
62maxx
Nov 21, 2006 12:04 PM
