Crankshaft f22a1
Old Jul 31, 2011 | 08:41 PM
nezt674's Avatar
Default Crankshaft f22a1
Hey gotta question... well my crankshaft still work. Or is it shot? Went to the salvage yard today, and all the crankshafts looked like this. But these pics are of MY crankshaft. Do i replace my crankshaft??? What should it look like? Help plez
Attached Thumbnails Crankshaft f22a1-2011-07-31-18.20.31.jpg   Crankshaft f22a1-2011-07-31-18.19.28.jpg   Crankshaft f22a1-2011-07-31-18.21.32.jpg
Old Aug 1, 2011 | 05:51 AM
Suggest taking a file to knock off the rough upsets and polishing w/ emery cloth tape till very smooth. Keyway looks fine. Problem would arise if you ever install new crankshaft seal. New seal would be damaged going over rough crankshaft end.
Looks like someone used a pipe wrench to turn the engine w/o a timing belt. Valves will be damaged. Cylinder head work necessary.
Old Aug 1, 2011 | 07:36 AM
g22cd5's Avatar
Supper Moderator
you might have a tough time getting the timing crank gear and harmonic balancer pulley on the crank with that type of damage.
Also if you get a crank from a junk yard make sure you pull the crank out properly with the right sequence and tq. specs when removing the bottom end. Otherwise you will need to get the crank balanced be4 you install it into your engine. Mine is still for sale if you want it.
Also you can use any crankshaft from any f22 engine.
f22a1
f22a4
f22a6
f22b
f22b1
f22b2
h23a
h23a1 ….all thos engines use the same crank and rods
pwcracker2002
Mar 28, 2008 08:59 AM
freemind
Nov 1, 2007 11:01 AM
mck52689
Jul 15, 2007 05:29 PM
Crazyguy
Jan 31, 2007 05:20 PM
hiTmanG11
Aug 2, 2006 02:28 PM
