F22b1 Turbo advise
Old Jan 21, 2010 | 10:36 AM
Turbo_Accord_2010's Avatar
Default F22b1 Turbo advise
f22b1 turbo stock fuel pump and injecters. do i need to upgrade if im only pucking 10 psi? and i have a bypass valve on my map sensor but the check engine light keeps comming on from time to time. i have a acf vtech and i played t=with the settings and got a huge performance boost but it runs like **** sometimes, when i full throttle it, i acts like its not getting anough fuel but when i back off to half throttle it has the power. and one more thing should i invest in a turbo tuned map sensor if so please throw me any web site for parts.
thanx much
Old Jan 21, 2010 | 10:45 AM
g22cd5's Avatar
Supper Moderator
Yes upgrade.
Also if your running auto think about a 5speed swap. autos don't like much more power over stock unless built.
Old Jan 21, 2010 | 11:24 AM
clutch811's Avatar
yeah at 10psi!? thats pretty high for a stock motor no tune. youre gonna burn it up along with that transmission. back that boost off until you can get some fuel upgrades and a tune. run 6 psi and take it nice and easy until you fix everything. youre probably running very lean and are going to burn valves and damage other internals.
Old Jan 21, 2010 | 03:01 PM
Tippman7641's Avatar
You definitively need bigger injectors, and if your running at 10psi, I hope your tranny has been either overhauled or built up, or it will go.
Second, make sure you tune your timming correctly, especially with that big of a boost.
If you have a rebuilt Auto tranny you will have more power then a 5-speed, reason being is you don't lose AS MUCH boost with an Auto, as opposed to a manual, and you probably can't shift anywhere near as fast as a built auto tranny can..
Old Jan 22, 2010 | 08:22 AM
Sweet! what would be the best injectors and fuel combo?
And will I need and engine management system?
Old Jan 24, 2010 | 05:58 PM
KevinAccord's Avatar
get a hondata and you will need some good old 550cc backed up by a nice walbro 225...
p.s: this should be under the turbo section
EDIT: also get a tranny cooler
elmerochingon
Oct 25, 2012 10:21 PM
Hobbin
93
Dec 18, 2011 09:12 AM
grocerygettertuner97
Jun 19, 2011 05:05 AM
Turbo_Accord_2010
Jan 8, 2010 07:39 PM
Turbo_Accord_2010
Nov 18, 2009 03:24 PM
