turbo advise
Old Dec 28, 2009 | 06:58 PM
Turbo_Accord_2010's Avatar
Default turbo advise
sup fokes,
i have an f22b1 @ 66,886. for some reason it gets low on oil every 3-4 weeks. there is no sign of leakage. the spark plugs arent covered with oil. i have a breather on the valve covern and i can see a little oil splatter but no enough to say its the cause. could it be the turbo?
Old Dec 29, 2009 | 12:35 AM
finch13's Avatar
VTEC can burn oil, especially if you drive the **** out of it. Valve guides, valve stem to guide clearance, pistons rings, etc. can bun oil.
Some oils burn faster than others...
Probably not the turbo... is it oil cooled?
Clogged PCV valves can cause oil to sputter through the breather. Cheap $4 part to replace.
Old Jan 8, 2010 | 07:39 PM
KevinAccord's Avatar
may also want to check the oil return piping. sometimes it leaks from there and you can't tell because it only leaks when the car is running
im currently working on that problem myself. good luck buddy
cortzeigler
Jul 30, 2012 01:58 PM
grocerygettertuner97
Jun 19, 2011 05:05 AM
Turbo_Accord_2010
Jan 24, 2010 05:58 PM
streetcustoms
Nov 1, 2007 11:31 AM
Accordn2dis
Sep 5, 2006 11:40 PM
