Need advice 1996 Honda Accord
Old Nov 2, 2023 | 03:18 PM
Dee's Avatar
Dee
Default Need advice 1996 Honda Accord
I have a 1996 Honda Accord that I could not smog due to a check engine light. I got a fix it ticket for registration which is all paid up. I just have to have the car pass the smog test.
I took it to a mechanic that said that by the codes that it needed a speed sensor and vapor canister purge sol. He quoted me 500 to 500 for parts and labor. He also told me to think about it because a car that old may not be worth fixing and that it may not solve the problem.
He put a speed sensor in and called me to pick up the car. He said that it may be a faulty speed sensor as the company he buys from sends him a lot of faulty parts. He's ordered another one but said that he did not think that was the problem and recommended that I just junk the car. He said that he suspects it the wiring and does not know anybody that can even work on that.
I'm just devastated as I am fighting stage 4 cancer and have no money for another car. This car runs perfectly and has no engine trouble other than speedometer and odometer not working. I did go through a CHP smog checkpoint and it passed. It makes no sense to me to have to junk a perfectly running car that won't pass smog because of a check engine light.
Any advice would be appreciated.
Old Nov 9, 2023 | 11:58 AM
TechQuestions's Avatar
Hello,
You didn't say what the check engine light code was.
My experience with so many error messages is that they
often have nothing to do with the problem, and
have nothing to do with the solution.
I have had better luck with searching for the code on Youtube.
One code I got years ago, P0401.
Exhaust Gas Recirculation Insufficient Flow
But the solution had nothing to do with the EGR valve.
The solution was to clean out some passages, filled with carbon.
See:
P0401 Honda Accord, Cleaning EGR Passages - EricTheCarGuy
EricTheCarGuy
1.77M subscribers
Nov 4, 2009
Hope this helps.
Old Nov 9, 2023 | 12:05 PM
On an unrelated subject, your cancer.
There are a number of alternative solutions to cancer.
See some documentaries below and do your research.
Cancer the Forbidden Cures - Full Documentary
Old Nov 9, 2023 | 12:06 PM
The Beautiful Truth
Old Nov 9, 2023 | 12:07 PM
From a Cancer Survivor
Top 3 Things that everyone can do everyday to stay Healthy
- this one is very informative, and he speaks from successful experience
accordd89
Jan 19, 2020 01:44 PM
blob gnarly
Nov 9, 2019 08:49 AM
thisandthatintx
Apr 19, 2007 04:52 PM
Will5
Sep 13, 2006 07:22 PM
1990WineAccord
Nov 20, 2005 03:33 AM
