timing belt
Old May 1, 2005 | 04:54 PM
stan2973
Default timing belt
hi everyone right im changing the timing belt on a 91 honda civic dx so far it was easy but heres the catch i cant seem to get the crank pulley off . man i cant even get the stinking bolt loose does anyone have any tips on getting that bolt loose and just to help me out which direction does the bolt loosen . i know the engine spins counterclockwise so that leads me to beliieve that the bolt loosens clockwise . i just wanna know how to remove the bolt without spinning the engine
Old May 3, 2005 | 10:32 PM
Evlampius's Avatar
Default RE: timing belt
theres a special tool for that - ask your local garages if you can rent that tool from them or may be buy it at local Autoparts stores.
Old May 23, 2005 | 12:42 AM
joshuaaaronalpert's Avatar
what is a timing belt, i'm kinda new.
Old May 23, 2005 | 05:56 PM
6thgen's Avatar
ORIGINAL: joshuaaaronalpert
A timing belt rotates your cam gear...your cam gear is connected to you camshaft. It's called a timing belt, because the position of your cam gear effects the timing of your camshaft.
www.howstuffworks.com check out that site...it'll teach you more about engines.
Old May 23, 2005 | 09:10 PM
Do you think that replacing the timing belt would be a good investment? Would a new cam shaft be better? How hard would it be for an 87 accord with like 130K miles?
Old May 23, 2005 | 09:34 PM
6thgen's Avatar
Replacing the belts is part of the maintenance of the car...items that wear need changed everynow and then. Replacing a camshaft is often a performance mod, rather than a maintenance. Camshafts are solid and grinded down to the profile (or shapes) that it takes. So for maintenance don't worry about the cam.
Old May 23, 2005 | 09:42 PM
Hey 6thGen, thats a good site for the answers..
Thanks for putting it in there for all to see...
WheelbrokerAng
ORIGINAL: 6thgen
john_pyro
Aug 4, 2019 05:06 PM
5.0stang
Apr 23, 2013 06:37 PM
ss485
Feb 23, 2011 08:18 PM
Jay 3rd
Feb 17, 2008 10:54 PM
Tony1M
Apr 1, 2007 05:42 PM
