Tranny Swap Question
Old Nov 23, 2008 | 04:18 AM
chezden78
Default Tranny Swap Question
hey guys, im new on this website but wanted to ask, i have a 2003 accord coupe v6 3.0 and its an automatic trans, but im planning to save money and swap it over to a 6 speed, just because it still has low miles and it makes scense to swap it out, i was going to order everything i need from the dealer just so i know im getting the best but i dont have any idea what i need so if you could help and teach me about what type of things i need down to a dime, also if you have any recommendations on where else i can go to buy the parts, and also what are the steps to swapping it out, and about a scale from 0-10 on difficulty please help me out, any comment is a very good help i could use all your guys comments on this one, thank you
-brandon
Old Nov 23, 2008 | 11:34 AM
Default RE: Tranny Swap Question
not positive on all these parts as it is a list for the 5th gen, but it will give you a general idea.
1. 5 speed transmission
2. 5 speed starter
3. 5 speed shifter assembly w/ shifter cables
4. 5 speed drivers side axle
5. 5 speed intermediate shaft
6. 5 speed clutch pedal assembly
7. 5 speed brake pedal arm
8. Clutch master cylinder w/ reservoir and lines
9. Clutch line from Clutch master cylinder to clutch dampener
10. Clutch dampener assembly
11. Clutch line from Clutch dampener to 5 speed tranny
12. Clutch line from 5 speed tranny to slave cylinder
13. Slave cylinder
14. Clutch
15. Flywheel
16. 5 speed mount
17. 5 speed mount bracket
Old Nov 23, 2008 | 09:19 PM
skatingclaybird's Avatar
car-parts.com
bigtex
Feb 21, 2018 11:08 AM
yamabu2
Oct 15, 2012 09:20 AM
tranwreck
Apr 30, 2009 09:27 AM
fendigyal
Oct 7, 2006 09:46 AM
