Transmission problem or motor mount?
Old Sep 17, 2008 | 03:34 PM
oc
Default Transmission problem or motor mount?
Hi,
I am driving a 2005 Accord. RecentlyI found out that when I press the gas pedal, I hear slight rattling noise from passenger side and I can also feel the gas pedal is slightly vibrating(even when I release the gas pedal). The second problem I have is that when I release the gas pedal(most obvious around 40mph), I can hear a veryhigh-frequeny "shoooo" sound like the wind blowing from the hood. Once Ipress the gas, the sound goes away, but when I release the gas, it comesback again.A mechanic said it has to be the motor mount. Another mechanic said I need a transmission flush. It may be no big deal but the noise, especially the one when I release the gas, is very annoying. Sometimes I can hear it very clearly even if the radio is on and the window is on. Personally I think the vibrating has to do with the motor mount but I have no idea about the noise when I release the gas pedal.Any suggestions?
Thanks in advance.
Old Sep 17, 2008 | 07:58 PM
finch13's Avatar
Default RE: Transmission problem or motor mount?
Well, you're probably due for a tranny flush anyways. Make sure to use Honda ATF Z-1 and drain/refill it 3x. Don't use a flushing machine, unless they do it at the Honda dealer.
If it's a motor mount they will ether be broken or the rubber will be gone. Check the front, rear, and side motor mounts.
Old Sep 20, 2008 | 06:33 PM
kendo's Avatar
i'll bet it's the motor mount because of the gas peddel
and4rik
Feb 9, 2010 08:50 PM
baer77
Feb 27, 2009 03:47 PM
Yangster
Sep 5, 2006 08:28 PM
Markus26
May 17, 2006 09:28 PM
