V6 tranny swap
Old Oct 6, 2006 | 01:24 PM
jamaicancord
Default V6 tranny swap
Well rite now i have a f23 an i was wonderin if it was worth jus keepin the 4banger an hookin it up or get a a v6 an finding a man tranny swap because i would rather a v6 manual but they dont make any an if this swap is possible bout how much do u think it will run me an does anyone kno anyplace ont he east coast
Old Oct 7, 2006 | 05:14 PM
YeuEmMaiMai's Avatar
Default RE: V6 tranny swap
it is very expensive to do a V6 swap to an I4 car since you will just about have to change EVERYTHING including the instrument cluster
Old Oct 14, 2006 | 12:59 AM
legionofone's Avatar
its not as bad as he makes it out to be... personaly though... if u could find a front clip off of a V6 the full front u would be basicly set... then u could just swap everything and see were each part came from
Old Oct 14, 2006 | 01:49 AM
Chiovnidca's Avatar
Sounds expensive.
Old Oct 15, 2006 | 04:07 AM
lets see...this is just what comes to mind
Instrument cluster
AC lines
radiator and cooling fans
Motor mounts(larger capacity)
Drive shafts
Transmission
Engine
ECU
Brakes and ABS module lines (front) and disks if they are drums in back
Suspension (you need heftier springs as V6 is 200lbs heavier)
Wheels (5 lug versus 4)
engine accessories (alt PS pump AC compressor)
Might need a new steering rack as well depending upon if the I4 one is in the way or not
bigtex
Feb 21, 2018 11:08 AM
tranwreck
Apr 30, 2009 09:27 AM
dannnnnn
Oct 4, 2006 06:37 PM
02SE_VTEC
Oct 11, 2005 05:53 PM
