*problem*
Old 06-02-2009, 01:28 PM
Et5291's Avatar
Default *problem*
i found a high pitch whine coming from my engine when i start it up and run it. it gets higher pitched the higher i rev. i cant quite tell where the sound is coming from but i'm not sure if its a belt or something worse. any help would be greatly appreciated thanks. i have a 95 f22b2 btw
Old 06-02-2009, 02:05 PM
Alternator diode bridge getting flaky? If so, it would change when you turn on every blower, headlight, defogger, etc...
Recent/new timing belt? Too tight?
Old 06-03-2009, 07:57 AM
Et5291's Avatar
i havent had the timing belt changed since i bought the car. The car didnt start doing this until my transmission was going out. if i start driving it it will make the noise along with the speed of the engine. high rpms high pitch. you get the point. sounds like a belt to me but i honestly have no idea
Old 06-03-2009, 08:59 AM
00AccordLX5spd's Avatar
Registered User
Can you get someone to rev the engine while you look under the hood and try to pinoint the noise?
Old 06-03-2009, 10:48 AM
Et5291's Avatar
i was trying to do it myself by reving it from under the hood but it was hard to focus on where the sound was actually coming from. ill try to do it when i get home later.
trouble
08-21-2012 07:46 PM
jkrueger2020
03-10-2011 02:18 AM
kellysa111
05-01-2009 08:35 AM
mahones
10-13-2008 08:24 AM
92Inspire
08-13-2006 03:37 PM
Quick Reply: *problem*
