00 Accord EX Coupe Fuel Pump/Sending Unit Question
Old Sep 1, 2015 | 01:10 PM
jweb's Avatar
Default 00 Accord EX Coupe Fuel Pump/Sending Unit Question
I'm working on my daughter's 2000 Accord EX 3.0 Coupe and am in the process of getting everything lined out to replace the fuel tank. There's a broken white wire on the pump/sending unit assembly that I'm trying to figure out how serious it will be to repair. I found this photo on the net and it shows the wire in question. CAN ANYONE HERE TELL ME WHAT IT DOES AND IF i CAN JUST SOLDER IT BACK TO THE SILVER barrel looking end that it broke from? (sorry, caps lock was on)
Attached Thumbnails 00 Accord EX Coupe Fuel Pump/Sending Unit Question-%24_57.jpg
Old Sep 1, 2015 | 02:21 PM
Turtlehead's Avatar
Either solder it well or replace the crimp fitting.
Old Sep 1, 2015 | 03:38 PM
jweb's Avatar
I've been searching the net to find out what that part is and so far only found it is a "sensor", that's it. After looking at mine closer, there doesn't appear to be anything to solder to, and I'm pretty experienced with a soldering iron. I'm going to try to shoot a pic to post.
This is the best I can do for now. It appears to have a very small piece left that I'll try to solder. In the meantime, if you or anyone else knows what this sensor is, I'd still like to know more about it. Thanks
Attached Thumbnails 00 Accord EX Coupe Fuel Pump/Sending Unit Question-20150901_145838.jpg   00 Accord EX Coupe Fuel Pump/Sending Unit Question-20150901_145710.jpg
Old Sep 1, 2015 | 03:46 PM
jweb's Avatar
I could be wrong but maybe it's a sensor for the "low fuel indicator" ? Hope I can solder it properly. These sending units are almost a hundred bucks.
schaicho24
Jan 6, 2014 05:45 PM
tropicalexplorer
Oct 27, 2010 01:30 AM
xaznxeclipsex
Sep 28, 2007 05:07 PM
IWL BCNU
Sep 13, 2007 05:35 AM
Triblade
Jun 29, 2006 11:54 AM
