02 LX v6 p1298 stored but no check engine light
Old Jan 2, 2013 | 06:07 PM
dtridente's Avatar
Default 02 LX v6 p1298 stored but no check engine light
Hi I have a lx coupe that has a sputter/hesitation at around 3500-4000 rpm. Almost as if the trans is slipping. I scanned for codes just in case, and found a p1298 stored. i looked at the fuse in the ip fuse box. its good. Im at a brick wall and dont even know if the sputtering has to do with the eld or not...Someone please help!
Old Jan 2, 2013 | 06:33 PM
Check whether the no. 6 (15A) fuse in the driver's under-dash fuse box is blown.
Old Jan 2, 2013 | 06:51 PM
dtridente's Avatar
Its good.
Old Jan 2, 2013 | 06:52 PM
dtridente's Avatar
Will this code cause that symptom I described?
Old Jan 3, 2013 | 07:14 AM
dtridente's Avatar
Finally got another code to store, also rough idle after a long crank. P0336. Are these sensors cut and dry? Usually if the code sets its the sensor?
Old Jan 3, 2013 | 07:46 AM
P1298 = electrical load detector
P0336 = crankshaft position sensor
Each code isn't a guarantee that it's a bad sensor. A dirty/loose/corroded wiring connection can also cause these codes.
I would think the ELD cannot cause the sputterring. It's job is simply measuring the electrical loads so your ECU can decide when to shut down the alternator.
proton8d
Sep 9, 2013 06:05 PM
brandon0409
Sep 8, 2013 11:05 AM
shaney
Dec 3, 2007 06:44 PM
