'03 Accord Blower stopped working
Old Jul 13, 2011 | 10:19 PM
KCW Honda's Avatar
Default '03 Accord Blower stopped working
I have a '03 Honda Accord LX w/ 2.4
My fan just stopped, not even intermittent, just stopped. I took the fan out and hooked it up to the battery and it works like a champ, so I looked on here and someone had the same problem and they told him to change out the motor blower relay (14.99 @ O'Reillys) so i gave that a shot and the did not fix it. What would be the next logical choice the motor blower resistor?
Help.....https://www.hondaaccordforum.com/for...anyways%2A%2A/
Old Jul 14, 2011 | 01:06 PM
bicklebok's Avatar
I guess you checked your fuses? Sorry, but I have to ask.
Wonder if you can find a wiring diagram. That would surely help. Use a test light and back track.
Old Jul 14, 2011 | 04:52 PM
There are two things you should do:
Check HVAC codes. See https://www.hondaaccordforum.com/for...-code-s-34589/
If you get code N, replace/repair transistor. See :https://www.hondaaccordforum.com/for...-repair-40796/
I will move this thread to the gen tech help forum, as it is the proper area to post these kind of questions.
Old Jul 14, 2011 | 09:53 PM
KCW Honda's Avatar
Default Fixed!!!!
Well I tried to check the HVAC codes but I don't have an Acura and my console isn't set up that way...however the link you provided help out. I went down to Radio Shack, bought the resistor $1.19, soldered and now it is fixed! You guys are awesome. Thanks!!!
Old Jul 14, 2011 | 10:37 PM
You should use that resistor as a temporary fix.
Read the notes I put into that writeup about using a fuse.
What you really need to do is replace the transistor and the thermal fuse under that board. What is likely happening is that the transistor is wearing out and overheating, thus blowing the thermal fuse. The thermal fuse is there to stop that module from overheating. You basically bypassed that safety mechanism, and you should repair properly.
Old Jul 14, 2011 | 10:45 PM
I recently found an 03-07 manual for an accord. Here are the directions from that manual. See if this procedure works for finding codes.
1.Turn the ignition switch ON (II).
2.Press the AUTO button and then the OFF button. Continue to hold both buttons down for 1 minute.
If there is any problems in the system, the temperature indicator will light up the segment (A through Q) corresponding to the error. The temperature indicator will then alternate every second between displaying ‘‘88'' (all segments lit) and the error code segment (A through Q).
NOTE: The system will only display the DTC when the AUTO and OFF buttons are pressed. If you release the buttons, the display will go blank. To return the display, simply press the AUTO then the OFF buttons again.
Old Jul 14, 2011 | 11:21 PM
KCW Honda's Avatar
Does that say anything about what to do if you dont have Auto or OFF? I have an 2003 Accord LX, 2.4L
Old Jul 14, 2011 | 11:32 PM
No it doesn't. All it says is with or without navigation.
I don't know the subtle differences in the 03-07 accords. There could be differences between the sedan/coupe, 4cyl/V6, EX, LX, DX, or leather.
You could post a pic of your HVAC controls. I'm not sure if you are overlooking something, or if you have a different HVAC panel.
crashdummie
Nov 22, 2013 11:31 PM
Tola
Sep 13, 2012 12:51 PM
Honda Man For Life
Apr 9, 2012 09:38 AM
Quentus
Aug 21, 2011 04:17 PM
dbennett3
Aug 11, 2008 11:49 PM
