03 accord engine no compression
Old May 25, 2011 | 05:58 PM
icecream man's Avatar
Default 03 accord engine no compression
My 03 accord has quit running. It is a 2.2 4 cyl it made a rattling noise and stopped. The starter turns and the belt goes around , the cam timing chain is intact but the cam sprockets do not turn with the starter. Any ideas?
Old May 25, 2011 | 06:05 PM
It sounds like the timing chain broke, or something that drives the timing chain broke. You will probably have to remove the timing chain cover to find a possible problem.
If the camshaft is not moving and the pistons are moving, then the valves likely got damaged.
Old May 25, 2011 | 06:41 PM
When you say belt do you mean accessory belt? And the cam gears don't move so neither does the timing chain?
It also sounds to me like the timing chain broke.
Old May 25, 2011 | 07:27 PM
ChicagoBob123's Avatar
I am not that familiar with this but can the key be missing from the cam gear?
How do you know the timing chain is intact?
Old May 25, 2011 | 08:58 PM
EXV6NIGHTHAWK's Avatar
If the crankshaft is turning (belt turning), but the camshaft is not turning, I think you have a timing chain problem. If you have been turning the engine over like that, you probably have bent valves, if not more severe damage. I could be wrong, but I don't think camshafts have keys.
Old May 25, 2011 | 09:24 PM
The mechanic says that the timing chain and all associated parts are fine. He says he needs to get more of the head removed first. the belt i refer to is the serpentine belt and its movement tells me that the starter is working and engaging the fly to turn the engine but the cam chain is not turning.
Old May 29, 2011 | 11:06 PM
The engine lost oil pressure and the oil pressure runs the timing chain tensioner. The chain skipped and sheared off some teeth, the pistons hit the valves and the rest they say is history. The mechanic wants $3000.00 for a used one installed. I'm looking elsewhere.
kj68135
Dec 19, 2010 09:17 PM
DA KID RYU
May 12, 2008 08:24 AM
GringoEJS
Jul 3, 2006 10:17 PM
nman
Jan 11, 2006 11:52 AM
Csparke
Dec 1, 2004 12:13 AM
