03 Accord Window Problem
  #31
Old 09-01-2014, 06:39 PM
Looking at the documentation for the 2003-2007, the auto up/down function looks to be only for the driver's door window and not for the front passenger window. Just wanted to confirm with you, is this the case?
If so, the problem with the driver's window auto up/down function, and the passenger window closing by itself may be due to the driver's door multiplex control unit (which is part of the master switch).
Later Honda Accords (e.g, 8th generation) had the auto up/down function for both driver and front passenger.
  #32
Old 09-01-2014, 06:45 PM
Using the front passenger window switch, does it also have issues?
  #33
Old 09-01-2014, 07:49 PM
JeffN9's Avatar
Yes I'm 99% sure the auto up/down only works from the drivers side. Although I did most of the testing from the drivers side it seemed like it made no difference which switch I was using when it started acting up. When the window didn't operate from the drivers side it also didn't operate from the passenger side.
I have no doubt that the passenger motor was bad because the old motor wouldn't do anything. Now it's working but it seems like it's getting a lot of false commands.
  #34
Old 09-01-2014, 08:19 PM
1. My best guess from what you described, is a faulty driver's door multiplex control unit (MCU). The door mcu is part of the driver's master window switch. The driver door mcu also controls the auto up/down function.
2. I've attached the circuit diagram for the power windows. In the diagram, you'll see that Fuse No. 26 separately provides power to the front passenger window switch so that it can be directly controlled by the front passenger; without going through the driver door mcu.
The driver's door master switch can also control the front passenger window through the passenger switch by separately supplying power. My guess is that when the driver door mcu is acting up, it may interfere with using the front passenger window switch.
Attached Thumbnails 03 Accord Window Problem-power-windows-1.jpg   03 Accord Window Problem-power-windows-2.jpg
  #35
Old 09-01-2014, 09:39 PM
JeffN9's Avatar
It does seem like it's a control problem more than anything else at this point. What I wasn't sure about though was whether the passenger switch could cause the described symptoms by itself or not.
  #36
Old 09-02-2014, 03:51 PM
JeffN9's Avatar
Been checking prices for the drivers control unit. Ouch, they are not cheap.
Could there be a problem getting the remote keys to sync up with the new unit?
  #37
Old 09-02-2014, 04:01 PM
The remote transmitter programming should not be a problem if the driver's door mcu and the under-dash multiplex integrated control unit (micu) are working properly. The antennae is part of the driver's door control unit.
Instructions should be the same as page 9 of this bulletin:
http://www.google.com/url?sa=t&rct=j...74115972,d.eXY
  #38
Old 09-16-2014, 09:25 PM
JeffN9's Avatar
As a follow up.
The new drivers door mcu seems to have done the trick. Everything seems to be functioning properly now. I'm keeping my fingers crossed that it stays that way.
Thanks for all the help.
  #39
Old 09-17-2014, 08:43 AM
Good to hear. Thanks for reporting that it may be resolved.
Michael Bomes
09-09-2012 03:12 PM
ravenr106
10-21-2011 06:08 AM
ravenr106
10-20-2011 05:32 PM
2006accordexl-passmirrorbroken
04-12-2010 03:01 PM
mmazb3
11-26-2007 03:16 PM
Quick Reply: 03 Accord Window Problem
