03 Ex 5mt surging after replacing air duct hose clamp
Old Nov 2, 2017 | 08:06 PM
  #21
jaxflex's Avatar
Thank you for the response PAHonda. P0507 is the same code over and over. I have the cheap scanner from Wal Mart. $20 bucks. I think it will freeze frame. I will get a picture of readings and post them.
Old Nov 2, 2017 | 08:49 PM
  #22
jaxflex's Avatar
Here are pics of code reader freeze frame.
Attached Thumbnails 03 Ex 5mt surging after replacing air duct hose clamp-img_8411.jpg   03 Ex 5mt surging after replacing air duct hose clamp-img_8412.jpg   03 Ex 5mt surging after replacing air duct hose clamp-img_8413.jpg   03 Ex 5mt surging after replacing air duct hose clamp-img_8414.jpg   03 Ex 5mt surging after replacing air duct hose clamp-img_8415.jpg
Old Nov 3, 2017 | 01:44 PM
  #23
shipo's Avatar
If you have access to a compressed air source read on, otherwise disregard this post...
  • Feed compressed air into the exhaust pipe (if dual exhausts, plug one side).
  • Seal the feed source (probably a hose) so no air can escape past it thus forcing the air up into the engine.
  • Disconnect the intake system and seal the throttle body.
  • Open the hood and start spraying liberal amounts of soapy water all over the place.
  • You have a vacuum leak wherever you see bubbles.
Old Nov 4, 2017 | 01:23 AM
  #24
jaxflex's Avatar
Thank you, I do have a compressor I can use. The only thing I need clarification on is the “feed source “. I don’t know what that is.
Old Nov 4, 2017 | 09:21 AM
  #25
shipo's Avatar
Feed source: The hose from the compressor duct taped into the exhaust.
Old Nov 4, 2017 | 05:56 PM
  #26
jaxflex's Avatar
Got it,duh. Will try as soon as possible. Wanted to mention as my wife and I are using the car today, the cel has turned off. It will come back but what are the chances I have a leak if problem goes away and returns randomly?
CHUCKW
Jul 6, 2016 11:43 AM
brandon0409
Jan 28, 2014 07:02 AM
Adler
Feb 8, 2011 06:54 AM
ryanw2427
Aug 30, 2010 08:17 AM
superballz00
Dec 28, 2007 06:51 PM
