04 Accord - Fan on and off
Old Nov 22, 2013 | 10:26 AM
Dr. Drivability's Avatar
Originally Posted by Unknownforce
Cool, appreciate it. I'll probably dive into it this weekend. Thanks!
Let us know if this repaired the idle issue
Old Nov 22, 2013 | 10:38 AM
Unknownforce's Avatar
Will do!
Old Nov 22, 2013 | 11:55 AM
Never timed it, but the cycle time might be a bit short. That in turn MIGHT(?) be an indication of something happening with the AC.
Excess refrigerant charge? Have you ever added refrigerant without monitoring both high & low pressures?
Excess restriction in the expansion valve? That might also cause short-cycling. As well as possibly excess drag from the compressor.
Honda's idle-control system seems to be "programmed" with a certain amount of drag expected from the AC. If the AC has too much drag, the idle-control system doesn't handle it perfectly. So maybe this is an early warning of AC issues?
Certainly start out with cleaning the TB & IACV like the Dr. said.
Marmarita
Jul 24, 2013 10:19 PM
accord
Jul 1, 2012 02:17 PM
CDJDM07
Aug 24, 2011 09:51 AM
ramachan9
Jul 11, 2009 11:57 PM
lee_vh
Feb 23, 2009 07:07 AM
