07 Accord - Rear Defrost Not Working
Old Dec 11, 2011 | 10:23 AM
ltl lifer's Avatar
Well thank you accordhybridowner. I watched it and now think I understand! I am going to post a link to the video here for others to see! Thanks again!
Here is the video on how to check a relay...
Auto Repair & Mechanics : How to Test a Car Relay - YouTube
Old Dec 28, 2011 | 07:35 AM
ltl lifer's Avatar
I checked all of the fuses/relays for the rear window defogger and found them all to be good. Upon further inspection, I found that the connection in the rear was disconnected. Hooked it up and it works great. As a side note, this car had been in an accident several years ago that damaged the rear end with extensive repair done. Re-hooking the connector was one part that failed to be connected.
It works great now.
Old Jan 9, 2018 | 10:20 AM
Willy-Accordelx07's Avatar
Default Next step please
Good afternoon,
I had done all these steps before I get to the forum, everything is fine!... I cannot find the way to check the little black box in my rear side window, near to the airbags in drive side... how to check if thes box is not damage?Beside this box, whatelse J May look for?Tkx
First things to check are the fuses. For the under hood fuse box, check the No. 14 (40A) and No. 2 (30A) fuses. No. 2 is if you have an EX or EX-L. (Your owner's manual will show this too.)
Also check the No. 30 (7.5A) fuse in the under dash fuse box.
With the button/switch light coming on, the fuses may possibly be okay; but, check them anyway just in case.
If fuses are okay, move on to the rear window and visually inspect the defogger lines on the window for cuts/breaks.
If that is okay, it may possibly be the rear defogger relay located in the under hood fuse/relay box.
There can be other causes too for it not working. But, I am not going to get into those due to it becoming more complicated.
Old Oct 19, 2019 | 09:16 AM
Kodo1479's Avatar
Default Having similar issues.
Joslinm
Oct 25, 2013 10:43 AM
Jonah805
Jul 26, 2011 06:08 PM
MSA
Nov 14, 2008 01:26 PM
honda123
Nov 13, 2006 05:25 PM
honda123
Nov 13, 2006 02:08 PM
